I love Tmpgenc, free, option filled and reliable. However I keep running into small issues.
Mainly: Tmpgenc seems to add 'extra' size to files. I use a bitrate calculator to ensure that my files are the right size, then other programs assume the file is much larger then it should be.
Nero and VCDEasy will tell me that the disk is MASSIVLY over size, upwards to 150mb oversized, then I can load the exact same mpegs into DVD-Lab, and they fit nice and snuggly.
No, no, I am encoding the files correctly... The average bitrates are correct, it's just that certian programs 'think' the file is better then it should be, and others don't. So some programs think I'm filling 80 or so mins of data on them, while Nero will tell me that the disk will be 100+mins and freak out.
I'm not using a bitrate that's actually to high, I'm sure of that. -
Originally Posted by DJ_Izumi"Art is making something out of nothing and selling it." - Frank Zappa
Sounds like the other programs are padding the stream
If your making an mpeg1, then the bitrate may not be what you told it to encode at. I know you said your sure about the bitrate, but i had a similar problem and all i needed to do was change a setting in the video tab under advanced settings in tmpgenc to mpeg non-standard, not for sure if this applies to your situation but just a thought.
Ripping DVDs as MPEGs using TMPGenc --- loss in quality?
By DieselsDen in forum DVD RippingReplies: 5Last Post: 21st Sep 2010, 12:09 -
Problems converting larger than 640x480
By Karlton in forum ffmpegX general discussionReplies: 11Last Post: 25th Apr 2010, 23:38 -
can someone explain why extracted files are larger?
By mickthetree in forum Newbie / General discussionsReplies: 7Last Post: 8th Dec 2008, 22:28 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 18:55 -
Larger File Type
By AudioSync in forum Newbie / General discussionsReplies: 3Last Post: 18th Mar 2008, 11:20
