  1. Whenever I convert an MPEG to another format it analyzes the file before converting. When I convert a movie it takes like 6-9 hours to analyze and convert the whole thing. Is there any way to skip the analzying process so it just starts converting?
    Apr 2002
    The State of Frustration
    Yeah. Use CBR as opposed to 2-pass VBR.
    Hello.
  3. Great! Thanks a lot.
  4. Unless you are using max bit rate, VBR will look better. Sure it takes twice as long, but once its done, the final product looks better if you set the avg bitrate to the same CBR bitrate. ie VBR 300min 2000avg 2520max will look better then CBR 2000, file sizes will be the same.
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    The "analyzing" is the first pass of 2-pass VBR. It can take twice as long as CBR but it gives smaller files, therefore more minutes per disk, while preserving quality. I encode overnight.
    Use CQ mode
