I wonder hot these subtitle sofware really works?
Does it automatic put subtitle on the avi or mpg movie when running it?
Or do u have type all the words Žby "u self" for adding subtitles?
Any can explain it for me, please?
Please help me out, coz Im just a newbie! =)
I don't know which program "these subtitle sofware" refers to, but to give you an answer of some sort:
The Vobsub filter for VirtualDub takes the subtitles from a DVD rip and puts them into your VirtualDub output. It's easy and you can choose different streams if your rip has different language subtitles.
The subtitler filter for VirtualDub takes a Sub Station Alpha script and puts those subtitles in the VirtualDub output. If you have a .ssa script it's as easy as picking the filename.
Sub Station Alpha is a program for creating a script. This is what you use to type in the words yourself, if you have a script or are a bilingual translator. It is designed to be used with a Video Tape genlock or Chromakey device, but can b used with .avi's if you use the subtitlr filter.
(Those are the "subtitle sofware" I know about, though you might be thinking about others.
Looking for a Subtitle Software with HH:MM:SS:FF mode
By gyzel01 in forum SubtitleReplies: 4Last Post: 2nd Apr 2012, 05:44 -
Software to synchronize a subtitle
By kyrcy in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2011, 12:01 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 18:03 -
Easiest software to convert Dual Audio/Subtitle MKV to WMV or AVI
By greasyspoon in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 13:43 -
Question about inconsistant subtitle timecode with different software
By jimdagys in forum SubtitleReplies: 1Last Post: 2nd Jul 2009, 01:07
