Hi all,
I recently upgraded my Zoomplayer and was having some problems playing SVCDs with it - they would lock up. So I did some tweaking of the options and settled on using the WINDVD as the video decoder.
Previously I would simply used WinDVD standalone to play these SVCD movies but didn't like that I couldn't use the computer while the movie was playing. With other movies, I could use the computer, play the movie with Zoomplayer and the image on the TV would be the image of the movie only, while I could surf the net or whatever on the computer.
Now that I have done this tweaking, I can not get the images on the TV and computer to behave differently. What I want is to be able to play a movie on the TV in fullscreen, while also minimizing the player on the computer to do other things. This WAS working before but not anymore.
Does anyone know what settings in Zoomplayer would allow this type of separation? I have read (and previously experienced) that Zoomplayer was capable of dual-monitors but can't sort it out in the settings. Any help will be VERY appreciated!
Thanks,
Larry
Ill give you the same advice someone else gave me, try TVtool9 with this you can split the information to go into the tv while still using the monitor.
Does Zoomplayer has it's own subtitle renderer like MPC?
By natsume shin in forum SubtitleReplies: 5Last Post: 29th Oct 2008, 10:37 -
Zoomplayer won´t display DVD subtitles
By fk in forum Software PlayingReplies: 2Last Post: 17th Oct 2008, 05:34 -
No sound or DVB subs in Zoomplayer.
By bjur in forum Software PlayingReplies: 3Last Post: 20th Feb 2008, 10:43 -
Playing HD DVD And Blu-Ray in Zoomplayer
By bjur in forum Software PlayingReplies: 3Last Post: 13th Feb 2008, 10:07 -
How do I maximized the size of the video to fill the screen.(premiere pro)
By yunakokimama in forum EditingReplies: 0Last Post: 25th Jun 2007, 09:49
