I have an original VCD, and on the corner it has the WB (like when u watch TV u see a symbol of the station at the corner i.e. CNN) symbol and it also says Ultra VCD on the corner. Iam wondering is there anyway to get rid of the symbols so i can watch a movie that has no symbols.
thanks
vdub has a logo filter
where you can add your favorite logo
anywhere you want
tommy -
sorry , i thought you want to add logos
To remove logo i think you can only blur them
with another vdub filter
tommy -
Yes thats correct, the filter is called logoaway
when you use it, select a portion of the screen, use the XY setting, it will first blur then, then adjust the x-y power by blending it onti the movie. very nice but you can tell very slightly that the logo was ever there.
This also works with subtitles too.
Any questions? email ShiZZZoN- -
Just do a web search for the filter, its posted all over the place. You can't use vdub filters directly in TMPGenc but you could frameserv from vdub to TMPGenc. That filter is pretty good but I only use it to edit short clips. If you used it on an entire movie it would be pretty noticable.
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 09:54 -
HELP! Too Much Text - I Need Labelling Template For Text
By kasius in forum MediaReplies: 5Last Post: 6th Dec 2008, 17:08 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 11:38 -
Adding text over original text
By stixster in forum EditingReplies: 3Last Post: 17th Jun 2008, 06:14 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 16:50
