Please help.
I have some vob trailers that i like to convert to mpg but if i do so it have horisontal stripes over it i use tmpgenc encoder.
It also happens when i capture video from my DVCAM and convert it to VCD and it ony does this when the picture is moving fast.See picture
Stolla![]()
Results 1 to 10 of 10
Does it do this only on your computer, or on your TV as well? If you've had the opportunity to test it on your TV...
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
Its interlacing. There are guides on how to deinterlace on this site, do a search.
But if you are going to convert it to SVCD, or DVD and watch it on your TV, I wouldn't de-interlace it - it will make the motion in the video look funky.
Zefram Cochrane
2073 -
It does the same on pc and tv......by the wat can someone PLEASE help me with a template for TMPGENC that is a good quality and is the following specs "PAL 352X288 25fps 1150bps 48000" so what i am trying to say it must be full VCD settings but the audio must be 48000 and not 44000 i have tested it om my dvd and it works perfectly exept for the horisontal lines !!!!
Thanks everyone !!!
Stolla
What is your source?
Zefram Cochrane
2073 -
Sorry i dont understand what is it exacly that you want to know i am a bit new so please be patient
Stolla -
Not a problemOriginally Posted by Stolla
You had said in your first post that this also happens when you capture from your DV camera, but what is your current source video from? TV/VHS, a DVD rip, an SVCD that you are trying to convert to VCD?
What program(s) are you using to capture? How are you capturing? Via coax cable? Audio/Video (the red/white/yellow) cables? S-Video? What are you capturing to, AVI, MPEG? What are the settings you are using to capture? You mentioned PAL, so are you capturing at 25fps?"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
OK sorry.
I hav a panasonic dv-amera with a onboard firewire card and use studio8 as my software.
So its full digital capturing and even the avi file have horisontal lines.
When i edit the avi file and play it back to my dvcam is perfect but when i convert it to dvd or vcd and play it on my tv it have horisontal stipes.
Hope this helps
Thanks for the help so far.
Stolla -
I'm getting a v.similar problem. Converted Aristocats from VHS to DVD. Field order A, interlace VBR of avg 7k, Burn to DVD disk. DVD looks great on Computer when played, but when played on TV gets loads of horizontal stripes across the whole screen - really naff. Not an interlace problem, I'm using the Quantization CG/Animation. Any tips ?
Removing moving object from a video
By Lucky Starr in forum EditingReplies: 4Last Post: 31st Mar 2012, 16:39 -
Replace audio track + crop video black stripes
By calande in forum Newbie / General discussionsReplies: 0Last Post: 14th Jul 2011, 13:24 -
Fast moving scenes show multiple images
By Acg in forum Authoring (Blu-ray)Replies: 3Last Post: 20th Jun 2010, 18:00 -
Moving Maps In Video
By noelma in forum EditingReplies: 6Last Post: 4th Dec 2009, 07:13 -
mp4->xvid video moving too fast
By Snowcrystal in forum Video ConversionReplies: 1Last Post: 28th Jul 2007, 13:50
