Okay,
I've got a divx that is 24 frames... is this NTSC? should I choose NTSCFilm? (in Tmpgenc)
I've got a PAL (25frames) divx, however my TV is NTSC.. how do I go about converting it.. can I just load the PAL template and it will work on my TV?
I've got Princess Mononoke DVD and want to rip to SVCD... I thought I read that there are special settings you have to use for anime rips (or even cartoons for that matter)... using either TMPGenc, or CCE..
When creating SVCD's or even VCD's.. is there a majority opinion on using CCE or TMPGEnc? Will I notice a difference in quality.. (c'mon ppl.. read my minds..haha)
Also, if I use CCE, I have to disable audio.. so once i have the video file and extracted audio wav (From VDub), what's the best program to mix them?
Thanks everyone in advance.. hope to get them all answered in one fell swoop..
Cheers!
Quick Answers:
24 fps is a dumb rip - it's not a standard of anything
you do not have to make a NTSC VCD to watch on a NTSC TV - it will play a PAL VCD just fine
yes sometimes for anime you have to do 2:1 pulldown to avoid stuttering (but research this as I don't usually do anime conversions)
CCE is great - but harder to use - TMPGEnc is my fav because it's more flexible and on 2-pass SVCD there isn't a noticable difference
To multiplex (join the audio and video) use either bbMPEG of TMPGEnc MPEG Tools
-hope that helps -
fantastic!
thx stinky...
so for the 24 frame film.. would I use the ntscfilm template?
anyone else comment on the anime rips?
<font size=-1>[ This Message was edited by: hence on 2001-10-11 11:39:10 ]</font> -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
yea that would work fine - I've used NTSCFilm and PAL for 15fps DivX files - TMPGEnc works it out
I know you guys have answered this a lot, but on Burners
By tcory in forum Blu-ray RippingReplies: 3Last Post: 23rd Jan 2011, 20:39 -
LG BD390 Bluray Player w mkv/x264 support - Questions answered
By andor1999 in forum DVD & Blu-ray PlayersReplies: 17Last Post: 31st Oct 2010, 11:02 -
How do i get my questions answered on these forums
By dumwaldo in forum Newbie / General discussionsReplies: 93Last Post: 26th Mar 2008, 18:44 -
spumux button order is off [answered]
By raschko in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2007, 09:08 -
2 conversion questions
By rendez2k in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Jun 2007, 05:35
