Are there any tools available for converting a .ogm video file (Xvid video with vorbis audio - both which have quicktime codecs available) into a quicktime-friendly container? Neither ffmpeg nor mencoder seem to like .ogm files, and searches on versiontracker and macupdate for ".ogm" turn up zilch.
Does anyone know of a way to do this? Thanks for your help.
does mplayer play this file?
if so you can use mencoder to convert it to a valid .avi -
If your Mplayer won't play it, then you have an older version. Mine plays it just fine, and thus Mencoder would convert it.
What format are you trying to convert it to ultimately?
ALso, if playback is all you are after, and dont care for Mplayer, VLC has been able to play OGM files for quite some time now... -
VLC plays them just fine, but Mplayer seems to crash sporatically while playing them. when I tried encoding the files with mencoder, it kept giving me errors related to the audio.
The reasons I wanted them in a quicktime friendly format were so I could extract video/audio clips of my favorite parts, and so I could convert them to MPEG-2 for DVD playback -
i see... PM me your AIM contact details and I can help get you up and running. When dealing with multiple audio streams, things get a little more complicated using Mencoder.
thanks for the offer, but I've got it running now... updating to the latest panther binaries made everything ok.
I have a .ogm that will play fine under mplayer, and I also want to convert it to a useable format like the author of the original post, but I don't know the commands needed to convert the file to the quicktime-friendly container. Could you please tell me what I need to type into mencoder to the the file to be encoded into the file I would like it to be?
Thank you,
wolfwood87
How to play Quicktime with PNG codec on my videoplayer (not quicktime)
By Henkie in forum Software PlayingReplies: 0Last Post: 11th Nov 2011, 03:50 -
.ogm file
By d_animality in forum Authoring (DVD)Replies: 2Last Post: 29th Aug 2011, 08:19 -
.OGM help
By Moparbear in forum Video ConversionReplies: 2Last Post: 3rd Mar 2008, 19:08 -
.ogm to DVD
By Faty100 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 10:14 -
Question regarding .ogm
By Justin Wade in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 12:39
