  1. Hai all,
    I've got a DVD whit an 448 KB/s DD track, now I want to rip that track to my harddrive. How do I do that???
    please help,
    THX JCL
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Originally Posted by JCL
    Hai all,
    please help,
    THX JCL
    DVD DECRYPTER in FILE MODE and then STREAM MODE
    It can be a bit tricky to figure out so if you really can't seem to do it then just rip the movie in FILE MODE and run the VOB files through DVD2AVI and that will spit out the AC-3 audio.
    - John "FulciLives" Coleman
  3. Originally Posted by FulciLives
    Hai all,
    please help,
    THX JCL
    I tried DVD2AVI. My goal is to place subtiteles in the DVD. I got a m2v file from the video. I got the SUB files, but now I need the audio.
    When I ripped it to *.AC3, I got an error "Inconsisstent bitrate where found amoung audio frames. Bitrate should be consistance througout the stream (0xc1070052).
    I thing it is a setting thing but I don;t know whitch setting :S
    please Help,
    JCL
  4. Member FulciLives's Avatar
    May 2003
    To get AC-3 from DVD2AVI you need to rip the DVD in FILE MODE with DVD DECRYPTER and run the VOB files (just the VOB files for the MOVIE) through DVD2AVI and for audio select:
    TRACK NUMBER = NONE
    CHANNEL FORMAT = AUTO SELECT
    DOLBY DIGITAL = DEMUX ALL TRACKS
    MPEG AUDIO = DEMUX ALL TRACKS
    That will give you a D2V project file and spit out any and all MP2 (aka MPA) audio tracks as well as any and all AC-3 audio tracks.
