I want to upload the soundtrack from NBA LIVE 2004 to my mp3 player, but all of the tracks are in asf format. I have tried a ton of apps to try to convert it but none of them work. I am thinking maybe ea games encode teh soundtrack some how so no one would be able to rip it off. PLease help me, maybe some one done it before.![]()
Results 1 to 10 of 10
I have used AsfTools v3.1 and it tells me
With asf tools I tried converting it wav.
Opening C:\Program Files\EA SPORTS\NBA LIVE 2004\audio\music\xmsong2.asf
Invalid Header Obj ID
--->> Error while convering
File Closed.
VirtualDub 1.3c tells me that it cannot determine the type, when i try importing the files.
I have tried a few others and none of them worked, jrbling which programs did you use. -
I am thinking maybe i cant use virtualdub, because I am doing something wrong. I try importing by OPEN VIDEO FILE, but my asf is not a video file. Maybe there is some other way to import.
I tried both of those methods before and it didnt work, when I tried importing it into tmpegnc it tells me "can't open or unsupported".
Whats w/lame.exe
Could it be that I can't open asf files because I don't have some codec thats needed? -
There are asf codecs, that may be a problem, you can find one in the tools sections on this site.
when you were trying with asf tools, you mentioned you tried converting to wav, did you also try the 're-encode' option? 'Convert to Wav' will not work in every case.
I dont deal too much with asf so asf tools is the only program ive used. -
Re encodig doesn't work either. It shows
Reading source file information...
Invalid Header Obj ID. Exiting.
--> Can't read source file information. -
Get a ps2 movie player and play those files in that straight from the dvd game to see if they are playable .pss files. Just use the all files setting for them to show up.
"Knowledge makes a man unfit to be a slave."
Frederick Douglass
Covert a .mp4 movie's audio alone to mp3 without changing the video quality
By ckarvnd in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 12:02 -
cannot covert .ts file to anything
By vespera in forum ffmpegX general discussionReplies: 4Last Post: 29th Jul 2009, 01:05 -
Covert 4:3 DVD to 16:9
By phowe in forum Video ConversionReplies: 2Last Post: 8th Jan 2009, 16:26 -
MPG's won't covert
By Squid_uk in forum Newbie / General discussionsReplies: 3Last Post: 8th Jan 2008, 14:28 -
How to covert .lqt to Mp3
By mlong30 in forum AudioReplies: 3Last Post: 10th Aug 2007, 19:14
