hello, I have a project for school and I need some help. I need to take a few scenes from a movie, and edit them together, so that it looks nice. I tried going from the dvd to my camera (sony trv950), but when I tried to record on my camera, I got a copy protected message.
I have:
Final Cut 3 and Final Cut 4
OSex
Dvd Backup
Mac:
G4 800MHz
768 MB
60GB with 60GB firewire
Superdrive
Can someone please tell me how to get these to import, because FCP 3 says it will only import avi and quicktime files.
Help is greatly appreciated, as this project is due on Monday, thank you very much
**EDIT**
I have a Superdrive and DVD2oneX, but I would rather not go that route, as I only have DVD-R's
Friends don't let friends use Windows!
Elisha Cuthbert is so a total schorchcake!! -
First I'd say rip the DVD into chapters using OSeX (ie. movie with 15 chapters will give you 15 individual .vob files) and find the files with the scenes you want.
Download mpeg2decX (free) or DVDxDV ($) or Miraizon Cinematize ($)
http://homepage1.nifty.com/~toku/software_en.html
www.dvdxdv.com/
www.miraizon.com/
Choose the .vob files with the scenes you want and convert them to a Quicktime DV stream (NTSC or PAL) depending on where you are.
Open FCP and import the DV streams you just created and edit them the way you want. -
The easiest way is to use 0Sex and extract the chapter off the disc.
To import into FCP, you can use Mencoder to convert them to a or a divx format. On your machine, this shouldnt take long at all.
This will assure you that your movie will also remain in sync.
Simply launch the terminal and type
mencoder -oac pcm -ovc lavc -lavcopts vcodec=mpeg4 [drag your vob file to the terminal window]
hit enter.... this will create a file in your home directory called "test.avi" that FCP will accept.
Hope this helps. -
how did you do it tpgo, the way zerosix described?
Actually I did it all under OS 9. I ripped with YADE the entire movie, converted the clips I wanted to Motion JPEG A quicktime movies, converted those to DV, editted with iMovie, and exported back out. With OS X that process is much shorter, but at the time that was the best way for me.
What type were you in high school
By johns0 in forum PollsReplies: 16Last Post: 24th Dec 2010, 00:11 -
school video editing
By Jynxmr in forum EditingReplies: 5Last Post: 6th Dec 2010, 13:23 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49 -
Need Youtube video to play in WMP for school project.
By iamaqt2 in forum Newbie / General discussionsReplies: 5Last Post: 12th Nov 2007, 13:14
