I didn't realise there is so much to this subject and having read all the posts here I haven't found a solution. Perhaps the following can help someone or someone may have the answer...
I am using Ulead VS 5 and the DVD plug in to burn SVCDs, they won't play on the Samsung. It recognises them as Video CD 1.1 (after an age loading) then moves to the first track and displays the times, etc. On play nothing but disk spinning. I am using HP CD-RWs.
I tried a TDK (blue) CD-R and was told no disk.
I then tried Nero and Easy CD creator using the raw AVI file and have the same problem.
It looks like the Samsung but I have done this using a brand new CD-RW in the past. Is it the disks?
The Samsung is also hardware modified for region 1, would this be a factor.
Thanks.
glawsterGuest
glawsterGuest
From Samsung...
We can advise that this model is of a single-laser design and is not CD-R compliant. It is possible that different makes/batches of discs may give some success but this cannot be recommended by Samsung.
Reds look wrong for Rec.709
By Anonymous344 in forum Newbie / General discussionsReplies: 11Last Post: 23rd Apr 2011, 19:14 -
Durabrand DPV-709 ??
By tecobala in forum Portable VideoReplies: 5Last Post: 25th Dec 2007, 13:06 -
Durabrand PDV-709 (Portable DVD Player) Hack Code needed
By Caribsurfer in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Dec 2007, 10:49 -
"Internet Revenge". A Strange Tale of Cyber Jealousy!
By moviebuff2 in forum Off topicReplies: 1Last Post: 27th Oct 2007, 06:20
