I have been trying unsuccessfully to somehow capture the audio portion of my Stevie Ray Vauhgn DVD which is his Austin City Limits concert. Everything I have tried has not worked. Fairly new at this, so any help would be appreciated.
First of all you have good taste,that's a great concert.
I would use DVDDecrypter->IFO mode->Stream Processing->Demux.Then use AC3Tool to convert to WAV and www.cdwave.com to split into tracks.
You could also connect the audio from a DVD player to your line-in on your soundcard using CDWave to capture and split. -
Thanks for the help. I'll try it out. Wow quick response. Cool site.
OK I used DVDDecrypter, now in AC3 program there are 5 or six tabs to click on. Which one do I chose to convert to a WAV format?
conversion blu-ray to dvd that select audio/subtitle tracks as requirement
By wisitch in forum Video ConversionReplies: 1Last Post: 5th Dec 2011, 05:13 -
By wisitch in forum Video ConversionReplies: 4Last Post: 25th Nov 2011, 07:04 -
Easy way to extract (demux) audio tracks from Blu-ray folder?
By ricsee in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2011, 11:12 -
How to strip audio or subtitle tracks off a Blu-Ray Disc
By ppeterr in forum Authoring (Blu-ray)Replies: 6Last Post: 2nd Jul 2010, 13:45 -
Identifying Audio Tracks in Blu-Ray Rip?
By Browncoat in forum Blu-ray RippingReplies: 3Last Post: 26th Dec 2008, 12:30
