This has probabbly been asked many times, oh well. I understand that when burning VCDs, SVCD, and cDVDs/MiniDVDs a 650mb and 700mb will hold more then 650 or 700mb of Data.
I'd like to know -why- this is, I doubt it is the work of Pixies... but then agian, you never know.
When burning a disk as a VCD/SVCD/MiniDVD, what is the actual maxium amount of data a 650mb and a 700mb CD disk. I'd like to know this so I can be a little more accurate on the space I have for menus while using DVD-Lab.
Simple, burn the video CD as an image file with no error checking files. I put 825MB on a 700MB CD as a SVCD all the time. I belive this is also called 'Mode 2'. You can also 'Overburn', but using image files, this isn't needed. Not sure what the max is, I let the software (DVD2SVCD) figure that out.
they use two slightly different formats when burning to the disc. Data uses mode1 which alllows 2048 bytes of data per sector while svcd vcd use mode2 which allows 2324 bytes per sector. The difference is that a data CD "wastes" the extra bytes on error correction. If you think about it, if one byte is wrong in a program then the whole program is corrupt, whereas if one pixel on the screen is the wrong colour for 1/25th of a second it is immaterial. You may think im joking but IBM IS working with pixie dust to enhance the storage capacity of their hard drives.
The electronic components of the power part adopted a lot of Rubycons.
Is avi best for storage?
By hurleyvcr in forum Capturing and VCRReplies: 5Last Post: 29th Dec 2010, 19:44 -
Best storage media for audio (long term storage)
By The Sumerian in forum AudioReplies: 6Last Post: 6th Mar 2010, 12:15 -
CD Storage
By Nitro89 in forum Off topicReplies: 5Last Post: 1st Aug 2008, 11:13 -
Best format for storage
By trikcard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th Apr 2008, 10:18 -
Is optical media storage more stable than magnetic media storage?
By bevills1 in forum ComputerReplies: 24Last Post: 5th Apr 2008, 05:32
