Hi,
I copied to Video_TS folder from my DVD-R to my Hard drive.
What program do I need to edit out commercials and other content from these .VOB files?
I do not want to do any converting of the original video format. I want to edit out clips from the .VOB file and save them as clips for burning onto a new dvd-r.
what is an easy and excellent program for doing this?
does it matter how I name the files that I cut out of the original?
thanks,
Kat
tmpgenc dvd author, select open dvd and choose the video_ts folder and then you can use the built in editing tool and remove the commercials and reauthor to a new dvd.
You can also use dvd shrink.
Any program to edit .ts or .m2ts files?
By yic17 in forum EditingReplies: 3Last Post: 18th Jan 2010, 01:29 -
What program can import and edit MJPEG files?
By yic17 in forum EditingReplies: 4Last Post: 26th Dec 2009, 13:32 -
How to edit/Remove Commercials from .ts files captured by ProgDVB?
By MounaLafi in forum DVB / IPTVReplies: 4Last Post: 2nd Oct 2009, 07:41 -
edit .VOB files
By vali in forum Newbie / General discussionsReplies: 3Last Post: 2nd Aug 2008, 04:23 -
EDIT! Program only converting 1st VOB file?
By chronic777 in forum DVD RippingReplies: 2Last Post: 17th Aug 2007, 05:14
