Results 1 to 10 of 10
  1. hi all,
    i just want to edit my vobs files (extract with the awesome tool: dvddecrypter) without re-encoding... I don't want to loose quality... Whats the best way (software) to Edit/cut vob files with no reencoding process?
    i think its easy, but i dont find the solution anywhere?
    thx you all
  2. i ve downloaded ifoedit... and i dont understand... i just want to cut some part of one vob file (music video) and get one vob file with only this part of the old vob file... (still without re-encoding)
    Mar 2003
    Uranus
    Why do you want to keep it as a VOB ?
    Are you going to make a DVD with it ?
    If so , TMPGenc DVD Author will import a VOB , allow you to edit it ,
    and make the DVD.
    DVDShrink will make a new DVD with a selected portion of an old one also.
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    ChopperXP will let you cut vobs directly.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  6. I tried Womble MPEG-VCR and while it appears to be a terrific program, I've yet to get it to make a cut without messing up the audio. I *am* using the latest download version and have emailed techsupport with zero reply todate.
  7. Originally Posted by FOO
    and make the DVD.
    Hello,, I was trying to do the same thing.. I try your method FOO,, but it didnt' work.. TMPGENC DVD AUTHOR wouldn't let meimport VOB file.. can you help me plz.. i got ver. 1.6 now when i import the VOB file it said:
    *This is an illegal video file
    This is an illegal video file.
    For DVD-Video you can only use the following video formats:
    MPEG-1 Video, MPEG-2 Video
    North America
    Along this thread, I have worked with TMPGEnc DVD Author in the past. Largely it works, but with two drawbacks. I am wondering if these drawbacks have been fixed, or if there is another known method.
    Drawback 1: Any subpicture streams are stripped out. This is not good for editing together elements where a foreign language is subtitled. Does anybody know if the current version keeps subtitles intact, and if so, how to accomplish that?
    Drawback 2: If the output VOB files exceed 4.7 GB, they won't recompress in Pinnacle InstantCopy, which I use. I get an error every time with output from TMPGEnc DVD Author. My current workaround on this is to do the math ahead of time and compress before doing the edit. This usually involves setting the values manually, burning to a re-recordable, then re-ripping the disc.
    Any help from experts on TMPGEnc DVD Author or similar tools on Drawback 1?
  9. Just VOB or you want to keep whole DVD? VideoReDo or DvdReMake could be useful.
