I am newish to DVD backing up and have been given advise by a friend to use DVD shrink. I have been able to backup 99% of my DVD's but have run into a problem with one. When I load up DVD shrink then put a DVD in, the program then Analyzes the film. Half way through analyzing I get an error message which says something like;
CRC (Cyclic Redundancy Check) Error. This stops the DVD from being backed up. I am able to rip the DVD using Smartripper so I take it the DVD is OK.
Could anybody recommend any piece of software that will let me backup the information so all I will then need to do is drag and drop the Video files into Nero to create a DVD Video.
Cheers
Welcome to the forums, brampton2222.
A "Cyclic Redundancy Check Error" is usually an indication of the disc being dirty or physically damaged.
SmartRipper (and DVD Decrypter) is simply better at ripping such discs than DVD Shrink.
If you have already ripped the whole DVD with SmartRipper, you have all the required files.
You can only burn them if they fit on a DVD-R, obviously.
If they don't, simply use DVD Shrink "Open files", selecting the "VIDEO_TS.IFO" file, and do the backup as usual.
DVD Shrink Problem?
By LCE in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2010, 07:38 -
Problem using DVD shrink 3.2
By aldago in forum Newbie / General discussionsReplies: 12Last Post: 13th Feb 2009, 20:28 -
DVD Shrink- Reauthoring Problem
By MPO in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2009, 11:42 -
Dvd Shrink Problem
By letty in forum DVD RippingReplies: 5Last Post: 23rd May 2008, 08:09 -
DVD Shrink problem
By lapetite_66 in forum Newbie / General discussionsReplies: 27Last Post: 10th May 2007, 10:21
