Hi there:
I used graphedit to extract the audio file from a divx movie with dts
audio. The output audio (.wav) is fine and I can use it for SVCD but the
problem is Graphedit only generated the .wav file for a while. After that, it seems to stopp outputting the wav file (around 400 MB). Does anyone
know why? is this because there is a file size limit in Graphedit?
I got graph figured out
--file >>Avi Splitter>>[avi<->ac3/dts]>>intervideo audio decoder>>wave dest>>file name.
my file was 500+megs so i dunno what to tellya, maybe install build.011116 is what i used. good luck -
Actually!! There is no any problem about the file size
I think I am just stupid.
I am glad that you figure it out because the way you did is exactly
what I did to retrieve and convert the wav file. Now I have no
problem to burn the divx with dts to SVCD. I dont know why
people say it is impossible to burn a SVCD from a divx with dts sound.
Hope somebody will find it useful.
Vegas AVI 2gig rendered file size limit
By Gargalash in forum EditingReplies: 2Last Post: 17th Nov 2008, 10:12 -
Is There a Practical File Size Limit For Streaming FLV?
By phild in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2008, 10:13 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 15:30 -
VDub/MOD cant limit my file size?!?!
By GangstaRap in forum Video ConversionReplies: 6Last Post: 29th May 2007, 05:36 -
.wav and .dts file problems
By bskies in forum AudioReplies: 2Last Post: 20th May 2007, 04:23
