Could somebody please shed some light on what I'm doing wrong. I'm capturing video with a Studio DC10+ from VHS and it works fine. But when I go to convert it to mpeg using tmpgc no video shoes up, only the audio does. If anyone know what I'm doing wrong some help would be greatly appreciated.
Thanks.
If this is the first time you are using the TMPGEnc, you'll probably find that the VFAPI Plugin for TMPGEnc (you'll find it on the same site you downloaded TMPGEnc) hasn't been installed correctly.
One thing I've found that works is that you should try disabling the OpenDML function in the VFAPI section. I've found that always works.
Maybe I'll learn something here, but this happened to me when I tried to encode the "freshly" captured avi. I found I needed to render before the mpg encoding would occur.
I had the same issue. Go under the drop down menu "Options" then "Env. Settings" and seect the AVAPI Plug-in tab. Then increase the AVFPI Compatibility reader (something like that) priority by right clicking on it. That may do the trick.
m2ts-file doesn't show video
By chrit in forum Blu-ray RippingReplies: 5Last Post: 19th Apr 2012, 11:28 -
Burn AVI + SRT, but doesn't show up on TV
By waro in forum SubtitleReplies: 3Last Post: 19th May 2009, 11:21 -
Video doesn't show while playing .mp4 files
By shiningwizard in forum Video ConversionReplies: 2Last Post: 17th Jul 2008, 02:16 -
Hard subbed AVI doesn't show subtitles
By rsamsson in forum SubtitleReplies: 4Last Post: 28th May 2008, 04:44 -
Video TS folder doesn't show up after DL.
By crowheart in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2007, 11:56
