I really need help. I am trying to back up my DVD, Wrong Turn, and i get a error in TMPEG Plus (Version 2.58.44.152). I am using DVD2SVCD Build 3. The error states, "File "C:\Program Files\DVD2SVCD\Movie\TitlePicture.bmp.avs can not open or unsupported." I haven't used DVD2SVCD in a while, because i re-installed all my software on my computer. Recently, I have added another 256 MB stick of RAM into my CPU. What can i do to clear this error. Any help A.S.A.P would be greatly appreciated!![]()
hey thanx man, so right now i don't have ANY, i mean ANY codecs installed. Do you or anyone else know which ones i need to install?
Something else has came up under the environmental settings under TMPEG. When i go under there, all VFAPI plug-in files have a check mark by them besides the Avisynth/VirtualDub script reader v0.1[b]. What do i need to install? Can anyone help me fix this, or maybe you Tommyknocker. Thanks
Everything is almost okay. You are looking for where the Direct Show Priority is located in the list. It should be the first one listed, and should have a setting of two or higher. If it is not, make it so.
Hello.
tmpeg - no sound on output file
By greytop1 in forum Video ConversionReplies: 1Last Post: 3rd Mar 2011, 16:20 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 06:23 -
Tmpeg 2.5 will not encode .avi
By WuTangDvD in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2007, 13:01
