I have been using Nero ultra express v.6 to copy 4.7GB dvds to 4.7GB DVD-R discs. I have been doing this by choosing to burn DVD files and then copying the video_ts and audio_ts folders into nero then burning them.
On my multi-region DVD player the copied disc plays in black and white but on my mates multi region it plays in colour!!!
Could this be an incompatible TV causing this or something else?
Cheers
Welcome to the forums, evilsatan.
As you rightly guessed, your tv is probably not multi-standard (PAL/NTSC). -
thanks for your help, would I use TMPEnc to change the DVD from NTSC to PAL? how is it possible to do this if I do not need to shrink the size of the DVD?
Cheers -
Or you could try & set your Dvd player to output RGB then it should play in colour.
:P
Try your Dvd players set-up menu it’s usually under picture settings choose Video out you should now see the option for VIDEO - S-VIDEO- RGB.
Captured video is in black and white (NTSC vs PAL problem?)
By Helena in forum Capturing and VCRReplies: 27Last Post: 18th Apr 2023, 18:34 -
Problem: Video Black and White in Samsung MM-DG25, How to change video outp
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jan 2011, 11:11 -
black & white only, cables problem?
By majel in forum DVB / IPTVReplies: 1Last Post: 4th Jan 2010, 09:51 -
Problem with S-Video: only getting black/white, Composite works fine!
By x92 in forum Capturing and VCRReplies: 20Last Post: 22nd Jun 2008, 09:05 -
Black and white picture on NTSC television from "region free" DVD
By psears in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 13:00
