Okay I have an AVI file I am converting to DVD. I want to know how I can get my AVI file that is 576x240 resolution to a compliant 16x9 with widescreen letterboxing. I want a true widescreen, it seems whenever I mess with it I can't get that. To test my theory I put in a widescreen movie from my dvd collection and can notice the difference. If I can't do that then I want to make a Fullscreen that is non squished. If anyone can help me with this I'd appreciate it. Either way I would like to know to make my resolution or change it in the future if need be to make a fullscreen and or widescreen that is correct ratio.
You may be confusing resolution (576x240) with aspect ratio (4x3 and 16x9). I don't know what software you are using or your conversion method. If you use TMPGenc then use a DVD template to give you the correct DVD resolution, select 1:1 for source aspect ratio and full screen (keep aspect ratio) for video arrange method.
Oh.... and you might want to pick one of the guides and just follow that."Art is making something out of nothing and selling it." - Frank Zappa
Megui Resolution problem
By thezanny in forum Video ConversionReplies: 3Last Post: 9th Mar 2011, 08:34 -
Input resolution problem?
By fritzi93 in forum DVB / IPTVReplies: 1Last Post: 21st Oct 2009, 05:14 -
Half D1 resolution problem
By sebrame in forum Authoring (DVD)Replies: 9Last Post: 30th Jul 2008, 09:18 -
Why does this happen? Resolution problem.
By bananadude in forum EditingReplies: 8Last Post: 14th Jun 2008, 02:47 -
HD TV Resolution Problem
By jemoto in forum DVB / IPTVReplies: 9Last Post: 29th Mar 2008, 04:45
