Greets,
Recently my Sony DRX510UL has started to fail 100% of its burn/verify. It finishes the burn, but almost every single file then shows as a failure on the verify.
I am running Nero v6.0.0.19 and using the same spool I have been for a while (Verbatim 4x Datalife DVD-R). I also bought a spool of Verbatimg 2x DVD-R. The verify fails on both.
I downloaded and ran the Sony tester. The Sony tester does not burn a lot of data, but it passed. The only burn which has passed right now was <1GB (which I did just as a test).
Since its external, this is not a DMA issue. The system is a P4 3GHZ running on an Asus Canterwood board. Nothing is overclocked.
Does anyone have any ideas?
Thanks!
