Hey everyone.
I bought some new ram (512mb) and the shop added it to my other 512mb of ram to make 1gb of ram. But sometimes the computer says its 1gb of ram...and sometimes it says I only have 512mb of ram! Please help, whats wrong??![]()
Yeah but it should stil detect it. Either you have a problem with the slot on your board the ram is in, or one of the chips is bad, OR those two specific chips just dont like each other (strange but it happens). I would try just using the new chip an see how the system acts then as a test.
I know of a problem in XP under the system folder in the control panel, which at times displays the incorrrect processor speed, could it be this....
I've had lots of problems with RAM sticks not working well with each other. Crucial gave me the most problems. Kingston also did not play well with others. Make sure you at least use the same brand of RAM when upgrading or else this could be your problem.
Value ram
By jollyjohn in forum ComputerReplies: 19Last Post: 5th Mar 2011, 06:21 -
RAM!!
By HotDamn! in forum ComputerReplies: 14Last Post: 15th Dec 2009, 07:43 -
Refurbished RAM?
By videobread in forum ComputerReplies: 9Last Post: 13th Dec 2009, 20:08 -
RAM compatibility.
By A Traveller in forum ComputerReplies: 35Last Post: 20th Oct 2009, 13:09 -
more ram?
By Heywould3 in forum ComputerReplies: 7Last Post: 24th Jul 2007, 11:32
