Hi, I have an SVCD which spans across 2 CDs. I wanted to make it onto a single DVD, so I thought I would open the .bin files and extract the MPG file, join it and convert it to DVD structure. But either part 1 or 2 of the MPG files will not play, but plays on my DVD Player on my TV, I used mplayerc and that gives off two errors:
Stream 0
Media Type 0:
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Stream {E436EB83-524F-11CE-9F53-0020AF0BA770}
subtype: MEDIASUBTYPE_MPEG2_PROGRAM {E06D8022-DB46-11CF-B4D1-00805F6CBBEA}
formattype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 1
cbFormat: 0
Media Type 1:
AM_MEDIA_TYPE:
subtype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
lSampleSize: 1
cbFormat: 0
When I try to open the file in VirtualDub I get this error:
MPEG Import Filter: pack synchronization error.
I installed Nemo codec pack, and It still didn't play so I removed it.
What do you guys think?
thanks for the help...
Tried a Mpeg2 codec ? or PowerDVD or WinDVD?
Virtualdub can't open mpeg2/svcd, virtualdubmod or virtualdubmpeg2 can.
mkv wont play after merging .srt file to it
By vice86 in forum SubtitleReplies: 2Last Post: 27th Oct 2010, 22:41 -
Codec missing. Dont know which one. VLC wont play either.
By UmmAddan in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2009, 15:48 -
mpeg video wizard wont play audio
By acestu in forum EditingReplies: 4Last Post: 25th Aug 2008, 11:49 -
WinDVD7 wont play PAL dvd with mpeg audio correctly ?
By deejay.2001 in forum Software PlayingReplies: 2Last Post: 26th Apr 2008, 14:57 -
wmv file wont play nor convert
By excitezone in forum Newbie / General discussionsReplies: 7Last Post: 18th Dec 2007, 12:56
