When I open my ripping program, I get this error about the DVD being encrypted. Is there a program that can rip it, is there settings I can change, or am I screwed?
Results 1 to 11 of 11
what do you use as your ripper? have you tried playing it before you rip it.
get any dvd which removes the prodection while you are ripping,you have to start any dvd first
Any DVD is a Program -
I tried Smart Ripper, but it gets some many broken blocks the files come out less than 2kb.
Try DVDDecryptor........
I've tried SmartRipper, I think it 'may' be better in some cases for a really awkward movie, but DVDDecryptor should handle 99.5% of cases and its easier to use !!
Well, for me anyway. But, like most things asked about on here its all down to personal preference and choice
SmartRipper and DVDDecryptor seem to be the main 2 rippers people use
Alos, have you tried cleaning the DVD you're trying to rip first ?? If its covered in greasy marks and bits of stuff stuck to the surface, you will get problems when trying to rip it
Sometimes dropping the reading speed of the DVD drive (assuming it can be adjusted via the software) can make a difference as well, if a DVD is that badly scratched and you really need to get it ripped a slower reading speed could give the DVD drive a chance to get the data from a scratched part of the disk it might not have been able to otherwise -
While I was ripping some of my older movies with SmartRipper I had the same problem... If disk is slightly damaged or dirty, even if you can't see an obivous scratch SmartRipper won't have it... You may than try DVDDecrypter which has, once or twice, proved succesful where SmartRipper failed. But those two are equally good, I guess, the decision which one to use is mostly personal preference...
Did you try playing the DVD using your software dvd player such as PowerDVD? You should watch a little bit of the movie first and then try running SmartRipper.
dj matty b -
I wipped it off and used DVDDecrypter, and it worked, but I need an MPEG, not a VOB file. I tried DVD2SCVD and it used TMPEGenc, but the MPEG only plays on that computer. It doesn't work on my other computers. How would I get it, so it's just a regular MPEG that works in every computer?
Nevermind, after I started playing with the compression, I made it sweet, but 2.2gigs (it's only 10 minutes), then I found the MPEG thing instead of AVI and it came out good at only 110mb. Thanks.
Start Tracks for new type of encrypted DVD's - Running list
By Groty in forum DVD RippingReplies: 8Last Post: 27th Dec 2009, 21:04 -
SubRip can't rip directly from non-encrypted DVD?
By bizzybody in forum SubtitleReplies: 4Last Post: 19th May 2009, 15:37 -
Another Ghostbusters Film?
By Epicurus8a in forum Off topicReplies: 11Last Post: 30th Dec 2008, 17:26 -
Upconverting CSS encrypted DVD's
By Vrex in forum DVD & Blu-ray PlayersReplies: 14Last Post: 26th Mar 2008, 07:45 -
Convert a CSS Encrypted PAL VIDEO_TS folder to NTSC DVD with subtitles
By Lord Stinkfoot in forum MacReplies: 6Last Post: 25th Oct 2007, 18:35
