  1. Hi guys,
    I was trying to merge 3 *.avi files with "Avi Joiner", but 2 file is showing frame size 368 x 240 and one is showing 368x208.
    So I can't join these 3 files.
    How can I convert the frame size to same as other files? Which tool I should use?
    Please help freinds. Thanks
    Kodomali
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    I can tell you what I've done in the past, it might help: I converted some AVI segments in TMPGENC to VCD format so they are the same size (352x240 or whatever it is) then use the merge/cut feature in TMPGENC to make them into one file, then reencode the whole mess to one large file.
