  1. I convert a video divx to dvd with Tmpgenc and when I try to burn it with nero 6 the programe want convert again.
    What wrong , the file was never converted ???
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    If anyone is going to help you then you need to provide more information such as what format did you convert too? As you know TMPGEnc can convert to VCD or DVD etc.
    So please we really need as many details as possible when you or anyone asks a question like this.
    Otherwise we are just merely guessing and/or will not even bother trying.
    I'm not being rude. Just trying to be helpfull.
    - John "FulciLives" Coleman
  3. FulciLives, your are absolutly right my fault .
    I use Tmpgenc for convert a divx-avi movie to dvd NTSC
    I set on the fist screen of the wizard project " CBR MPEG-1 Layer II Audio mp2. After this I changed nothing on the wizard. After 5 Hours I get a mpeg movie. Here the problem started if I use nero I get the program to want to recode the movie.
    I use windows XP if this help.
    Apr 2003
    Largo, FL
    That could be theh problem. DVD is MPEG-2, not MPEG-1.
