I just bought CCE-Basic and I am getting ready to create my first DVD of some home footage shot with a DV cam. I would like the best quality from my encoder and was wondering if using the plug in produces the same quality as frame serving. Is there a quality loss? I know I will take a performance hit but I was wondering if I also take a quality hit going with the plug in.
Any thoughts? If I go Frameserver with Adobe, any recommendations which one to use. Is AVISynth a good one?
You should be concerned with quality first, then performance. If you have Premiere, you don't need AVISynth at all. It can do everything AVISynth can, and much, much more. I don't know if CCE basic comes with plug-in for Premiere or not. If it doesn't, you are really screwed, because many people get CCE SP with Premiere plugin for free :P
Maybe I was not clear. CCE Basic does come with a plug-in for Adobe and I like the fact that it is all in one application. The questions was do I lose quality using the plugin vs. frame serving. I would like to use the plug-in but not if it means a quality loss.
U shouldn't see any quality loss. But yes, Poplar was correct. Your input footage is more of a concern..
Can you use frame serving for video conversions?
By johnharlin in forum Video ConversionReplies: 2Last Post: 2nd Mar 2011, 22:39 -
Frame serving
By carlmart in forum Video ConversionReplies: 2Last Post: 2nd Jul 2009, 08:39 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17 -
aviSynth + CCE Basic (2.7) fails on certain scripts
By binister in forum Video ConversionReplies: 6Last Post: 11th May 2008, 00:23 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 31st Jan 2008, 23:24
