I am trying to narrow down the cause of reasonable quality DVD-R disks skipping and eventually `locking up` in a variety of desktop and pc players - changing media has so far not sorted it.
Is there an issue with labels (or even inks) - could some glues etc possible block the lasers ?? getting a hunch that it might be this.
Using both Sony DR510 and Pioneer 106 - same off both burners - off separate installations of DVDit .
Basically driving me mad - anyone any experience of this.....
Thank you !
Do you have paper sticker labels on the DVD's or printed directly? Paper sticker labels are a no-no for DVDs.
Sticky paper labels Joe ! - then why on earth are they advertised for DVDs....it did seem to gradually be leading up to them - and seems probably only `gets bad` when the glue sets ??
Thank you ! -
I had problems with labels on dvd's also..it played on some dvd players but not others..
you are better off getting some colored sharpi's
scott -
I recommend a process of elimination. Create a DVD without a lable and test it on the players that you had issues with. If the problem still exists then its your media else its the lables.
For the record, I have created over 700 DVDs and used lables on all of them with out issues. I can't say for sure why I have such a high success rate. Perhaps its the media I use (Maxell) or the lables I use (Neato) or both. Another factor may be my method of appling the lables. I never apply lables until the ink has properly cured. (15 - 30 min for Matte, 5 - 10 on Glossy).
Hope this helps
DMonty
Video Keeps Stopping On My Site
By Frustrated1 in forum MacReplies: 16Last Post: 5th Apr 2010, 00:59 -
How to burn DVD that plays all chapters without stopping?
By billdz in forum Authoring (DVD)Replies: 28Last Post: 2nd Nov 2009, 05:53 -
Play divx files without stopping
By occasional in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Feb 2009, 07:20 -
Skipping / Stopping Problem After Burning to DVD format
By shelglen in forum Software PlayingReplies: 4Last Post: 15th May 2008, 09:52 -
TMPGEnc DVD Author 3 - Stopping it Re-encoding
By Incast in forum Authoring (DVD)Replies: 12Last Post: 8th Aug 2007, 17:45
