I captured the Godfather with ATI AIW Radeon and MMC but chose 320 x 480 resolution instead of 352. DVD authoring programs won't accept it and I tried dvd patcher header but it didn't work. What else can I do with this file to make it dvd compliant?
Did you capture to MPEG? Or AVI?
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
Well, you could re-size it, but the quality will degrade and probably not be what you are loking for, but it's an option none the less.
For best results I think that you will have to re-capture at the desired resolution.
Always remember, it is better to capture more than you need and cut down than it is to not capture enough. You can trim the fat, but you can't make something out of nothing.
Change VOB Resolution
By Simmons in forum Video ConversionReplies: 4Last Post: 30th Aug 2011, 07:37 -
Change video resolution
By Browneyd in forum EditingReplies: 5Last Post: 11th Jan 2011, 10:34 -
Change resolution from 235:1 to 16:9
By ThaiJan in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2010, 14:16 -
How do I change video Resolution
By mmkk in forum Video ConversionReplies: 7Last Post: 31st Aug 2009, 17:33 -
Change resolution without recompressing?
By StoneGold in forum Video ConversionReplies: 9Last Post: 30th Sep 2007, 08:02
