Hi, I plan on producing DVD's to be sold on my website. I was wondering what kind of media I should be looking at for best compatibility with different DVD player models? My burner is a Pioneer DVD-R A05 and I was looking at RiteK G04's. For labels, I was going to buy the core DVD labels, since they seem least intrusive (I have a Halloween 666 DVD I bought from eBay which uses core labels).
Any comments or suggestions before I get started?
Thanks!
Results 1 to 9 of 9
I have the same drive in one of my systems. It is about a year old and I have tried several different media types. I have burned about 125 Ritek G04 (ones with orange label) with no coasters. I have used Nero, TMPG DVD Author, and DVD Decryptor to burn.
Would highly recommend the Ritek G04. -
Stick with the ritek's but think of getting printable's for a better looking finished product.
Plenty of threads of good printers in this forun.Not bothered by small problems...
Spend a night alone with a mosquito -
the ritek are the best but ive got a 105 and ive just bought 25 of the printable ritek for the first time and ive burnt 7 of them all coasters but they could be a bad batch so be carefull
i bought them at http://www.blankdiscshop.co.uk/ normal all the discs i get of them have been fine
I guess you will be returning themOriginally Posted by sunderland
If you do could you keep us up to speed on how they handle the problem.
Have used this store many times and never had a problem, but it has to happen at some point and would be good to hear how it goes.
Half way through 25 of these disk from same store and no troubles yet..
Lets hope it is a bad batch...
ive always used this store and never had problems before. sent them a email and they replied back straight away and said if i want to replace them i can so. will be doing that. cant complain about them they have been great
Nice one glad to see they are on the ball.
Yep have to agree they are a good campany not many will send out free samples when you are not sure about which brand of disk to change to.Not bothered by small problems...
Pioneer DVR-530H:Cannot burn to DVD-Rs, works with DVD-RWs
By boba_dk in forum DVD & Blu-ray RecordersReplies: 33Last Post: 31st Jul 2015, 13:24 -
Exploded DVD in Pioneer DVD Burner
By SE14man in forum MediaReplies: 1Last Post: 24th Apr 2012, 09:57 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
Does Pioneer DVR-112D burn DVD+R and DVD+R DL media well?
By palmtree in forum DVD & Blu-ray WritersReplies: 26Last Post: 4th Jan 2008, 04:22 -
What is the best DL media for Pioneer 1810 and DVR-710 drives ?
By MacPCConsultants in forum MediaReplies: 9Last Post: 2nd Dec 2007, 14:37
