Hi Im usuing the trial virtualdub to capture from my capture card.
The only thing is it seems to only record at 15 fps.
This seems to then look slightly slow when ive burned this to SVCD.
Is it posssable to change the fps in the free version.
First, there is no such thing as a trial version of VirtualDub. VirtualDub is 100% free.
Second, check the lower righthand corner of the VirtualDub window. You should see a little button that says "15.00fps"? Click it, and down will come a menu, and hopefully it will give you other fps settings. -
Hi Hilljack I cant see where you mean about the lower right hand side.
Is this on the main screen when you first open virualdub or in the capture screen. -
It should be on the lower righthand corner of the capture screen. There will also be a button to adjust audio frequency too.
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
Help with VirtualDub 1.9.7?
By hezbag in forum Video ConversionReplies: 4Last Post: 20th Oct 2009, 05:21 -
Virtualdub help
By Rogert in forum Newbie / General discussionsReplies: 10Last Post: 2nd Sep 2009, 15:00 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Help with VIRTUALDUB Please !!!!
By spliffy in forum RestorationReplies: 10Last Post: 30th Jun 2007, 08:28
