I have a .mpg file which plays fine in windows media player. When I edit it, the clip which is cut using TMPGenc has no audio. I have re-encoded it using TMPGenc and the video and audio at the beggining are fine, but then towards the end the audio and video have a delay to them so they are no longer in synch. The farther in the video, the worse it seems to get. I have tried to use mpg error scanning and correction programs, I have de-muxed and re-muxed the files...same problem. Because it isn't a consistant delay, I am not sure how to fix it. I can't just offset the audio or video as then it would mess up the rest of the video that is working fine.
Any suggestions?
Thanks,
Allen
Results 1 to 1 of 1
Why does your system have audio/video sync issues?
By Will Hay in forum Capturing and VCRReplies: 65Last Post: 15th Sep 2024, 01:15 -
Blu-ray Audio Video Sync Issues
By nerouser in forum Authoring (Blu-ray)Replies: 1Last Post: 24th Feb 2009, 15:38 -
Archos 605 Audio-Video Synchronization Issues
By analein in forum Portable VideoReplies: 5Last Post: 31st Aug 2008, 13:27 -
Sony SR82 Questions about Video/Audio Issues
By djtech2k7 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Jan 2008, 16:22 -
Audio issues with DVD camcorder files after editing
By stantheman1976 in forum EditingReplies: 2Last Post: 15th Oct 2007, 16:53
