O.k. not really sure how to ask this question, trying to turn Sex & the City into one avi, but because you have to access the menu in the DVD to view each episode, I'm only getting the first episode to encode. Any thoughts or suggestions on how to by pass this so that I have all episodes in conjuction? Hope that made sense....
I haven't really understood why you need to merge your AVI files, but I believe ffmpegX has such a function. You should be able to keep them separate and have different menu buttons in the DVD menu select different episodes, the way GOD meant it to be
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
ok........
This is what u do.......
Open the DVD folder, and on the first menu of FFmpegX, there should be a Title and Chapter selector. Choose the first episode.
Encode with your settings, then do it over again with the next episodes, either title or chapter.
using the SAME EXACT settings as the first episode, make the rest.
Open your first and second encoded episode, use the join feature. then take the newly joined avi, and the third episode, and join them, and so on and so forth.
I hope this helps.
Q"Good Luck 007"
In Memory of Desmond Llewelyn -
you can also cut and paste .avi files in quicktime pro - given that they were encoded with the same codec and settings (actually maybe they don't even need to be the same)
good luck -
wow, a real newb. You need to rip the dvd to ur HD with either OSEx or DVD Backup 1.3
Q"Good Luck 007"
how to merge multiple mp4 into 1 file
By carlos28355 in forum Newbie / General discussionsReplies: 6Last Post: 25th Oct 2012, 08:29 -
Merge multiple audio tracks from different files into 1 video file - sync
By heinza in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2012, 03:29 -
merge multiple avi to 1 single file
By carlos28355 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Oct 2010, 19:11 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 18:44 -
Merge multiple VOB then convert to DivX
By submanic in forum DVD RippingReplies: 24Last Post: 19th Sep 2008, 14:39
