K, so I made these menus with tscv, it's one hell of a bugged program but it gets it done... kinda. Anyway, it never renders the chapters when I click the 'make menu' of the 'chapter menu' creator... it's all black, that's not the way I want it!
What am I burning? Euh, cause I'm so nostaligc, I'm burning pokémon to cd, I loved that show when I was young, about 4 years ago
this is just my new thought about this... no to cvd!/svcd/vcd why not just create lower res dvd as 352x288 is a valid dvd spec, also 352x576 is also a valid dvd spec. These respectively replace vcd and svcd but ALLOW YOU TO USE ALL DVD tools. Many audio tracks and subtitles and menus properly supported. I cant really think of a problem with this except that if you are burning to a cdr then your player may not recognize it as a valid "dvd" as its not on the right media. any thoughts?
The electronic components of the power part adopted a lot of Rubycons.
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 22:46 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
TSCV on Vista
By mrcoolekin in forum Authoring (VCD/SVCD)Replies: 4Last Post: 11th Feb 2008, 23:04 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
