Hi All,
I currently have a Cendyne (read Pioneer DVR-104) that I exclusively burn Ritek G03 @ 2X with. I also have 10 Optodisk DVD-RW 1X that I use.
I recently jumped on the 4X Dual bandwagon by snagging an Iomega (read Nec 1300A) drive from Amazon.
Now I have to start all over with the media again, so here are my questions:
1) What is the current best firmware (hacked) for the Nec 1300A?
2) Now that I have the option, should I go to DVD+R or DVD+RW??
3) Since I am big fan of Ritek, I immediately looked at the Ritek G04's...Is there anything comparable??
4) Now that I can at least double my DVD-RW speed(2X) or even more with DVD+RW(2.4X), can someone suggest a good Rewriteable for this drive??
I have only had 1 bad Ritek disk in 300, so you can guage the quality I am looking for.
In advance, thanks for all the help....
Bama
I've been feeding my 1300a a steady diet of RITEK G04's (-R) and it's been a happy camper. Throw in some TDK 2x and it didn't notice. The cost on the G04's was a few pennies mor than the G03's in bulk, so personally I'd stick with RITEK.
As for RW's, I bought some RITEK RW's and been pretty hapy with them( I dont' use them that much, just to preview conversions on my player, usually in file mode).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Gaz:
thx for the info....Newegg has 50 - Ritek 4x for $58 shipped...Any better deal that you know of?
What about the Firmware Rev your using???
I know I have that FW site here somewhere...rpc1.org or something....
thx
bama -
bamafamily
leave well enough alone...if your 1300a is burning your choosen quality media successfully that is. Herrie's hacks are great, only if you need them (i will flash my original with his when bitsetting is implemented).
personally i use +dvdr medias from memorex, tdk, and verbatim. the 1st 2 are Ricohs and verbatim is MCC (higher quality than Ricoh). i use copytodvd 2.3.7 for all dvdrs, but need to resort to nero 5.5.10.42 to burn dvdrws...flawless. -
actually, I have not started burning with the Nec yet...(still in the box)
When I take it out tonight, I would like to know which firmware to go to to turn it into a 1300A brning machine...
hints??
bama -
stick with original for now...you won't regret it. bitsetting is coming soon for the 1300 via Herrie's hacked 1.08x
exactly what noki said, if it aint broke dont fix it, find some dvdr's of good quality and price (GO3 riteks spring to mind) and see if they work, if they fail then try updating the firmware.
Frustrated Sony HDR-SR12 Owner
By jehill in forum Newbie / General discussionsReplies: 20Last Post: 5th Jul 2009, 03:54 -
I'm now a PC owner
By tgpo in forum Off topicReplies: 17Last Post: 9th Feb 2009, 03:46 -
Pissed off Ipod Touch owner needs to vent
By ryangarfield in forum Off topicReplies: 10Last Post: 23rd Sep 2008, 14:41 -
New HDV cam owner, quick question.
By shadablade in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 1st May 2008, 23:17 -
Owner's Manual
By golfnut in forum DVD & Blu-ray PlayersReplies: 4Last Post: 17th Jun 2007, 11:37
