  1. Hi
    Using DVD-lab
    Is there anway to get rid of menu commands
    I just want the movie to run on insertion of the disk
    or
    from play movie command
    regards
    Mar 2003
    Uranus
    Hook your movie to First Play instead of a menu
  3. Hi
    Flaccid member or is that flassid meber
    Thanx for the help
    tried to read the help file but didnt seanything that
    relates to that
    will go back and have alook
    meanwhile if you know which menu it is under
    YES iam going to search around but n=must hav missed it somehow
    give us anod
    regards
    thanx for prompt response
    much appreciated
  4. Go to the connections window. Click the little cross just to the top of left of the window. Click on the 1st box in the top LH corner (forget what it is labeled, at work right now) and drag the connection to your movie. SImple as that.
  5. Hi
    Thanx managed that
    Go to compile ad it stops after 20 secs showing the start button again
    Do i have to put some decoder in
    or have i missed somethin out
    Have m2v and ac3 file as movie
    Used connections wizard to bypas menus clicked compile
    and it just apperas to stop after 30 ecs
    try start again
    stops and asks have i compiled yet
    anyone any ideas
  6. ancient
    or you can read my thread that shows how to use DVDShrink with DVDFab and still get original menus... (but the movie plays first, NOT the menu )
    https://www.videohelp.com/forum/viewtopic.php?t=185976&highlight=
  7. Hey
    Thanx guyz
    you are always a good hlp
    I was inviolved with a tricky project
    Converting an import dvd(NSTC) to work on my tv setup(PAL)
    On top of that i only have win98se so filed limit 4gb
    Itried tmeg author but needs ntfs sys
    so Ireverted to dvd-lab - and chose not to mux my m2v file
    So after my last entry to tis thread i muxxed and got result
    Leon the Professional is now PAL but onfortunately i have that
    'motion strobe' - BUT - Lip sync was near perfect
    I am dissatisfied with te motion strobe
    so its back to the drawing board for me
    once again many thanx to you all
    regards
    :P
  8. Are you SUR you need to convert from NTSC to PAL. Most TV's in the UK will happily accept an NTSC or PAL-60 signal from a DVD player if connected by Scart.
