    Feb 2003
    Indiana
    project.
    OK, here is what I did. I have 5 basketball games from Indiana's Final Four run of 2002. I made highlight reels of each one at 5Mb/sec, then linked them all together, rendered with LPCM audio using UleadVideoStudio 7 SE DVD, and burned them to a single DVD (the file was 2.87GB) using Ulead DVD MovieFactory 2. The first three play just fine, and the 2.87Gb file plays fine on my computer, but about 2/3 the way through the video, the video seems as if it's missing frames, just not a very smooth video. Is there a better burning software? I would think that if the file is fine on my computer, then the problem is somewhere between my burning software and the DVD itself. I have a Sony DRU-500A, and am using Sony DVD-R media.
    Thanks very much for your help. Indiana Fans worldwide also thank you.
  2. Member Devanshu's Avatar
    May 2003
    Have you tried playing it on other players as well? Maybe the problem is w/ your player.
    Are you talking about IU? If so, NOTRE DAME IS BETTER(I'm from indy too). :P
  3. yea, use Nero...
    forget about Unlead Movie DVD factory...whatever its called....
