I tried the method in the VCDhelp-guide: extracting the audio to a separate file. The conversion starts out OK, but after a while it slows down and halts...Is there an other way (of course, there has to be!!!)?
Jedor
Results 1 to 12 of 12
Search the Net for ASF and VirtualDub. Version 1.3c was capable to import ASF-Files. Later the author was forced by M$ to remove this support as it is a patent infringement.
CU
Schmendrick -
Record the audio from stereo out with an audio editor programme like goldwave and record the video with hypercam ( http://www.hyperionics.com/ ) as a last resort. I have to admit that I don't have experience with hypercam.
CU
Schmendrick -
Thanx Schmendrick for your good intentions, but Hypercam didn't do the job either. It messed with my Media Player.
Jedor -
Does this numerous times with Virtualdub 1.3c, get to Google my man!
perhaps then the asf file you have is actually DRM protected, and in that case your virtually out of luck (at least for the time being anyway) your best bet then would be to
A: use a video card and run the signal out of your pc and record it onto a vcr or what have you
B: use a screen capture program
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
Tmpgnc doesn't work
By better life in forum Authoring (VCD/SVCD)Replies: 3Last Post: 27th Nov 2008, 22:29 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58 -
SUPER doesn't work
By tedgrant in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2007, 15:36 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 11:07
sigh...Doesn't work either...
