I created a VCD by the book using TMPGenc 12a and then using Nero to burn the CD. I followed the directions to a T. No problems. I have a Sony PlayStation 2 but when i put the disc in it will not read the CD. Please Help.
If you want to be sure it's the VCD's fault then I suggest you try playing it on either your PC or a true DVD Standalone and not on a Sony PS2, as it may be able to play VCD's, it doesn't work well with all types of CDR media.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
The PS2 dosent play VCD's, it can with a mod chip though, about $10-15, look on the net
Really? I thought that there is still no way for a PS2 to playback VCDs... and I don't see how a modchip could change this (unless it contains code for a VCD player as well).
Regards.
Michael Tam
w: Morsels of Evidence -
well.....
The PS2 CAN play vcd movies....ehm....kinda......
There is a special tool to create/burn VCD movies to a disc which is playable on the PS2. Only problem is that those disc in turn cannot be played on a VCD/SVCD/DVD player
You can download the software to make one of these discs here:
http://granavenida.com/vcdspain/down/psx2/ps2.htm
The site is in Spanish. As far as i can see all software here is legal.
Hope this helps clear things up for ya'all.
pSyChO dAd
The difference between genius and insanity is only measured by success ! -
Of course you are correct.
However, I don't consider these discs "VCDs".
Regards.
Michael Tam
ehm, well there not.
I totally agree with you. These are just a way of getting your movies to play on a PS2. They have NOTHING to do with vcd's
Greetz,
pSyChO dAd
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
LG DV 390H - unable to play VCD
By rach1234 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 31st Aug 2010, 09:25 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 06:14 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 13:15 -
ACCURIAN APD-3955 play VCD?
By UltraVCDDVD in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2008, 13:48
