Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 11 of 11
  1. Hairyhamster
    Guest
    Hi all... i have the registered version, and for some reason after i recently formatted my machine and reinstalled software it will not create vob files.When i try to author all i get is creating new mpeg1 then creating mpeg2. Im left with 2 _dvd files but the program stops there and doesnt create the dvd folders, Any idea anyone please. I have reinstalled software but still the same, and used to work fine b4 the pc reeboot!
    many thanks
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can i see your log file?
  3. Guest
    mine is version 1.0 build 1.0.1359.23067 and i cant find a log option??
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Do a manual update from the update menu in the application & enter the update area. At the bottom you will see an area devoted to SVCD2DVD v1.5.
    I suspect if you upgrade you will have no more issues.
    CB
  5. Guest
    OK I have just upgraded to 1.5.... and works a dream!!
    once again hail to the best dvd software on the planet!!!
    (thanx cb!)
  6. Guest
    i am having the same problem with SVCD2DVD DEMO: v1.5,
    ******** Creating DVD Folders...
    Creating VTS #1
    Creating VTS #2
    ============ Complete ============
    ============ Duration: 01:59:10.1914704
    It says its creating the folders but when I go to the path I specified to have them, its empty. And in my source path it has all the ******_01_DVD files
    my source files total 3.74 gigs in size and my DVD folder drive totals 12.8 gigs in free space.
    Thanks in advance for the help.
  7. ^^^Thats me BTW. in my DVD Folder where the files are to created there is absolutely nothing, no folders, files, anything
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
  9. Starting SVCD2DVD DEMO: v1.5.1411.27829
    Begin time: 12:48:05 AM
    ******** Ripping SVCD images to get mpegs
    Analysing File: C:\stuff\Movies\DVD\svcdone1_01.mpg
    ++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
    ++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
    Analysing File: C:\stuff\Movies\DVD\svcdone2_01.mpg
    ++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0c.02]
    Analysing File: C:\stuff\Movies\DVD\svcdtwo1_01.mpg
    Analysing File: C:\stuff\Movies\DVD\svcdtwo2_01.mpg
    Analysing File: C:\stuff\Movies\DVD\svcdtwo3_01.mpg
    -->Processing 5 mpeg files.
    ############### New MPEG File ###############
    Type: SVCD
    Horizontal Res: 480
    Standard: NTSC
    Audio SampleRate: 44100
    ******** Preparing asset
    Truncating Asset.
    Truncating Asset - done.
    Now processing svcdone1_01_D.mpg 1/2 ...
    Now processing D:\Program Files\Badgersoft\SVCD2DVD DEMO #2\NTSCSVCD.mpg 2/2 ...
    ******** Demultipexing original mpg file
    bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
    speed increases by, Apachez and Christian Vogelgsang
    Saving stream 0xE0 into file C:\stuff\Movies\DVD\svcdone1_01_DVD.mpv...
    File C:\stuff\Movies\DVD\svcdone1_01.mpg is an MPEG-2 Program Stream
    pack header field flag value not allowed in program streams
    Saving stream 0xC0 into file C:\stuff\Movies\DVD\svcdone1_01-0.mp2...
    ******** Resampling audio from 44.1 KHz to 48 KHz
    ******** Multipexing elementry streams
    INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
    INFO: [mplex] File C:\stuff\Movies\DVD\svcdone1_01_DVD.mpv looks like an MPEG Video stream.
    INFO: [mplex] File C:\stuff\Movies\DVD\svcdone1_01_DVD.mpa looks like an MPEG Audio stream.
    INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
    INFO: [mplex] Found 1 audio streams and 1 video streams
    INFO: [mplex] Selecting dvdauthor DVD output profile
    INFO: [mplex] Multiplexing video program stream!
    INFO: [mplex] Scanning for header info: Video stream e0 (C:\stuff\Movies\DVD\svcdone1_01_DVD.mpv)
    INFO: [mplex] VIDEO STREAM: e0
    INFO: [mplex] Frame width : 480
    INFO: [mplex] Frame height : 480
    INFO: [mplex] Aspect ratio : 4:3 display
    INFO: [mplex] Picture rate : 29.970 frames/sec
    INFO: [mplex] Bit rate : 1845200 bits/sec
    INFO: [mplex] Vbv buffer size : 114688 bytes
    INFO: [mplex] CSPF : 0
    INFO: [mplex] Scanning for header info: Audio stream c0 (C:\stuff\Movies\DVD\svcdone1_01_DVD.mpa)
    INFO: [mplex] MPEG AUDIO STREAM: c0
    INFO: [mplex] Audio version : 1.0
    INFO: [mplex] Layer : 2
    INFO: [mplex] CRC checksums : no
    INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
    INFO: [mplex] Frequency : 48000 Hz
    INFO: [mplex] Mode : 0 stereo
    INFO: [mplex] Mode extension : 0
    INFO: [mplex] Copyright bit : 0 no copyright
    INFO: [mplex] Original/Copy : 1 original
    INFO: [mplex] Emphasis : 0 none
    INFO: [mplex] SYSTEMS/PROGRAM stream:
    INFO: [mplex] rough-guess multiplexed stream data rate : 2106896
    INFO: [mplex] target data-rate specified : 10080000
    INFO: [mplex] Setting specified specified data rate: 10080000
    INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 13019
    INFO: [mplex] New sequence commences...
    INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
    INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
    ++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c0!
    INFO: [mplex] STREAM c0 completed @ frame 131606.
    INFO: [mplex] STREAM e0 completed @ frame 94704.
    INFO: [mplex] Multiplex completion at SCR=284317842.
    INFO: [mplex] Video e0: buf= 62935 frame=094704 sector=00361350
    INFO: [mplex] Audio c0: buf= 4096 frame=131606 sector=00043783
    INFO: [mplex] VIDEO_STATISTICS: e0
    INFO: [mplex] Video Stream length: 728793088 bytes
    INFO: [mplex] Sequence headers: 2960
    INFO: [mplex] Sequence ends : 0
    INFO: [mplex] No. Pictures : 94705
    INFO: [mplex] No. Groups : 2961
    INFO: [mplex] No. I Frames : 2961 avg. size 34602 bytes
    INFO: [mplex] No. P Frames : 28821 avg. size 13328 bytes
    INFO: [mplex] No. B Frames : 62924 avg. size 3849 bytes
    INFO: [mplex] Average bit-rate : 1844800 bits/sec
    INFO: [mplex] Peak bit-rate : 3289600 bits/sec
    INFO: [mplex] BUFFERING min 15 Buf max 134306
    INFO: [mplex] AUDIO_STATISTICS: c0
    INFO: [mplex] Audio stream length 88439908 bytes.
    INFO: [mplex] Syncwords : 131608
    INFO: [mplex] Frames : 131608 padded
    INFO: [mplex] Frames : 0 unpadded
    INFO: [mplex] BUFFERING min 15 Buf max 683
    INFO: [mplex] MUX STATUS: no under-runs detected.
    Analysing File: C:\stuff\Movies\DVD\svcdone1_01_DVD.mpg
    ++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
    ++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
    Type: SVCD
    Horizontal Res: 480
    Standard: NTSC
    Truncating Asset.
    Now processing svcdone2_01_D.mpg 1/2 ...
    Saving stream 0xE0 into file C:\stuff\Movies\DVD\svcdone2_01_DVD.mpv...
    File C:\stuff\Movies\DVD\svcdone2_01.mpg is an MPEG-2 Program Stream
    Saving stream 0xC0 into file C:\stuff\Movies\DVD\svcdone2_01-0.mp2...
    INFO: [mplex] File C:\stuff\Movies\DVD\svcdone2_01_DVD.mpv looks like an MPEG Video stream.
    INFO: [mplex] File C:\stuff\Movies\DVD\svcdone2_01_DVD.mpa looks like an MPEG Audio stream.
    INFO: [mplex] Scanning for header info: Video stream e0 (C:\stuff\Movies\DVD\svcdone2_01_DVD.mpv)
    INFO: [mplex] Scanning for header info: Audio stream c0 (C:\stuff\Movies\DVD\svcdone2_01_DVD.mpa)
    INFO: [mplex] STREAM c0 completed @ frame 108932.
    INFO: [mplex] STREAM e0 completed @ frame 78414.
    INFO: [mplex] Multiplex completion at SCR=235405019.
    INFO: [mplex] Video e0: buf= 18946 frame=078414 sector=00299202
    INFO: [mplex] Audio c0: buf= 4096 frame=108932 sector=00036240
    INFO: [mplex] Video Stream length: 603488256 bytes
    INFO: [mplex] Sequence headers: 2515
    INFO: [mplex] No. Pictures : 78415
    INFO: [mplex] No. Groups : 2516
    INFO: [mplex] No. I Frames : 2516 avg. size 30011 bytes
    INFO: [mplex] No. P Frames : 23920 avg. size 12867 bytes
    INFO: [mplex] No. B Frames : 51980 avg. size 4235 bytes
    INFO: [mplex] Peak bit-rate : 3444400 bits/sec
    INFO: [mplex] Audio stream length 73202980 bytes.
    INFO: [mplex] Syncwords : 108934
    INFO: [mplex] Frames : 108934 padded
    Analysing File: C:\stuff\Movies\DVD\svcdone2_01_DVD.mpg
    Type: SVCD
    Horizontal Res: 480
    Standard: NTSC
    Truncating Asset.
    Now processing svcdtwo1_01_D.mpg 1/2 ...
    Saving stream 0xE0 into file C:\stuff\Movies\DVD\svcdtwo1_01_DVD.mpv...
    File C:\stuff\Movies\DVD\svcdtwo1_01.mpg is an MPEG-2 Program Stream
    Saving stream 0xC0 into file C:\stuff\Movies\DVD\svcdtwo1_01-0.mp2...
    INFO: [mplex] File C:\stuff\Movies\DVD\svcdtwo1_01_DVD.mpv looks like an MPEG Video stream.
    INFO: [mplex] File C:\stuff\Movies\DVD\svcdtwo1_01_DVD.mpa looks like an MPEG Audio stream.
    INFO: [mplex] Scanning for header info: Video stream e0 (C:\stuff\Movies\DVD\svcdtwo1_01_DVD.mpv)
    INFO: [mplex] Bit rate : 2450000 bits/sec
    INFO: [mplex] Vbv buffer size : 229376 bytes
    INFO: [mplex] Scanning for header info: Audio stream c0 (C:\stuff\Movies\DVD\svcdtwo1_01_DVD.mpa)
    INFO: [mplex] rough-guess multiplexed stream data rate : 2720800
    INFO: [mplex] STREAM c0 completed @ frame 112638.
    INFO: [mplex] STREAM e0 completed @ frame 64834.
    INFO: [mplex] Multiplex completion at SCR=243309275.
    INFO: [mplex] Video e0: buf= 9611 frame=064834 sector=00367558
    INFO: [mplex] Audio c0: buf= 3424 frame=112638 sector=00037472
    INFO: [mplex] Video Stream length: 739573760 bytes
    INFO: [mplex] Sequence headers: 4405
    INFO: [mplex] No. Pictures : 64835
    INFO: [mplex] No. Groups : 4406
    INFO: [mplex] No. I Frames : 4406 avg. size 26235 bytes
    INFO: [mplex] No. P Frames : 17450 avg. size 16942 bytes
    INFO: [mplex] No. B Frames : 42980 avg. size 7638 bytes
    INFO: [mplex] Average bit-rate : 2187600 bits/sec
    INFO: [mplex] Peak bit-rate : 2375200 bits/sec
    INFO: [mplex] Audio stream length 75693412 bytes.
    INFO: [mplex] Syncwords : 112640
    INFO: [mplex] Frames : 112640 padded
    Analysing File: C:\stuff\Movies\DVD\svcdtwo1_01_DVD.mpg
    Type: SVCD
    Horizontal Res: 480
    Standard: NTSC
    Truncating Asset.
    Now processing svcdtwo2_01_D.mpg 1/2 ...
    Saving stream 0xE0 into file C:\stuff\Movies\DVD\svcdtwo2_01_DVD.mpv...
    File C:\stuff\Movies\DVD\svcdtwo2_01.mpg is an MPEG-2 Program Stream
    Saving stream 0xC0 into file C:\stuff\Movies\DVD\svcdtwo2_01-0.mp2...
    INFO: [mplex] File C:\stuff\Movies\DVD\svcdtwo2_01_DVD.mpv looks like an MPEG Video stream.
    INFO: [mplex] File C:\stuff\Movies\DVD\svcdtwo2_01_DVD.mpa looks like an MPEG Audio stream.
    INFO: [mplex] Scanning for header info: Video stream e0 (C:\stuff\Movies\DVD\svcdtwo2_01_DVD.mpv)
    INFO: [mplex] Scanning for header info: Audio stream c0 (C:\stuff\Movies\DVD\svcdtwo2_01_DVD.mpa)
    INFO: [mplex] STREAM c0 completed @ frame 109225.
    INFO: [mplex] STREAM e0 completed @ frame 62889.
    INFO: [mplex] Multiplex completion at SCR=235986066.
    INFO: [mplex] Video e0: buf= 58263 frame=062889 sector=00368737
    INFO: [mplex] Audio c0: buf= 4096 frame=109225 sector=00036337
    INFO: [mplex] Video Stream length: 741998592 bytes
    INFO: [mplex] Sequence headers: 4309
    INFO: [mplex] No. Pictures : 62890
    INFO: [mplex] No. Groups : 4310
    INFO: [mplex] No. I Frames : 4310 avg. size 25609 bytes
    INFO: [mplex] No. P Frames : 16997 avg. size 17519 bytes
    INFO: [mplex] No. B Frames : 41584 avg. size 8028 bytes
    INFO: [mplex] Average bit-rate : 2262800 bits/sec
    INFO: [mplex] Peak bit-rate : 2366000 bits/sec
    INFO: [mplex] Audio stream length 73400100 bytes.
    INFO: [mplex] Syncwords : 109227
    INFO: [mplex] Frames : 109227 padded
    Analysing File: C:\stuff\Movies\DVD\svcdtwo2_01_DVD.mpg
    Type: SVCD
    Horizontal Res: 480
    Standard: NTSC
    Truncating Asset.
    Now processing svcdtwo3_01_D.mpg 1/2 ...
    Saving stream 0xE0 into file C:\stuff\Movies\DVD\svcdtwo3_01_DVD.mpv...
    File C:\stuff\Movies\DVD\svcdtwo3_01.mpg is an MPEG-2 Program Stream
    Saving stream 0xC0 into file C:\stuff\Movies\DVD\svcdtwo3_01-0.mp2...
    INFO: [mplex] File C:\stuff\Movies\DVD\svcdtwo3_01_DVD.mpv looks like an MPEG Video stream.
    INFO: [mplex] File C:\stuff\Movies\DVD\svcdtwo3_01_DVD.mpa looks like an MPEG Audio stream.
    INFO: [mplex] Scanning for header info: Video stream e0 (C:\stuff\Movies\DVD\svcdtwo3_01_DVD.mpv)
    INFO: [mplex] Scanning for header info: Audio stream c0 (C:\stuff\Movies\DVD\svcdtwo3_01_DVD.mpa)
    INFO: [mplex] STREAM c0 completed @ frame 106445.
    INFO: [mplex] STREAM e0 completed @ frame 61292.
    INFO: [mplex] Multiplex completion at SCR=229990546.
    INFO: [mplex] Video e0: buf= 53313 frame=061292 sector=00360681
    INFO: [mplex] Audio c0: buf= 4096 frame=106445 sector=00035412
    INFO: [mplex] Video Stream length: 725811200 bytes
    INFO: [mplex] Sequence headers: 4198
    INFO: [mplex] No. Pictures : 61293
    INFO: [mplex] No. Groups : 4199
    INFO: [mplex] No. I Frames : 4199 avg. size 26771 bytes
    INFO: [mplex] No. P Frames : 16553 avg. size 17729 bytes
    INFO: [mplex] No. B Frames : 40542 avg. size 7891 bytes
    INFO: [mplex] Average bit-rate : 2271200 bits/sec
    INFO: [mplex] Peak bit-rate : 2385200 bits/sec
    INFO: [mplex] Audio stream length 71531716 bytes.
    INFO: [mplex] Syncwords : 106447
    INFO: [mplex] Frames : 106447 padded
    Analysing File: C:\stuff\Movies\DVD\svcdtwo3_01_DVD.mpg
    Creating VTS #1
    SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    Creating VTS #2
    -->: DVDFolders creating table of contents
    ***: No .IFO files to process in H:" \VIDEO_TS
    ============ Duration: 02:02:35.0860944
    there ya go, hopefully we can figure this out cause I would really like to purchase the program
  10. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Ok, your log file looks perfect..... apart from the following line:
    Near the end.
    THis leads me to believe you are changing the dvd folders directory from the default. It looks like it may not like that but more likely it doesn't like the root of a drive. Can you try 1) a sub folder on H. If that doesn't work: 2) keeping the default for the DVD folders.
    Let us know the outcome please.
    CB
  11. hip hip hooray, making a subfolder did the trick, now to test it out in my dvd player. thanks for the help!!
