hello everybody, I have a problem with an AVI of mine: the volume is too low even when volume is set to max. I noticed that with ac3, I can raise the volume more. The audio format is "mpeglayer3 (mp3) (0x0055) ISO/MPEG"...what can i do to solve this problem?
Thank you for your help
You can split the audio out - VirtualDub can do this for you, or an easy way is to open the file in GoldWave, and Save as a wav.
You can then open the audio file in something like GoldWave and normalise the levels (in GoldWave, Volume->Maximise).
This will make the audio as loud as it can be without clipping/distorting.
You can re-encode the audio as an mp3 with GoldWave, or with VirtualDub. You'll probably need LAME plugged in to GoldWave, or the LAME ACM mp3 codec installed for VirtualDub.
VirtualDub can then put the audio and video back together again.
See the tools section for all of these programs.
cheers,
mcdruid.
DVD audio volume too low
By efiste2 in forum AudioReplies: 4Last Post: 28th Mar 2012, 16:06 -
Low Volume on Playback
By SE14man in forum Software PlayingReplies: 6Last Post: 28th Aug 2010, 11:45 -
Low audio volume
By Daz_uk in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2010, 13:34 -
Youtube: why the low volume?
By kevs in forum MacReplies: 3Last Post: 23rd Nov 2008, 06:07 -
After burning, volume is too loud/low?
By vieo in forum Authoring (DVD)Replies: 4Last Post: 12th Jan 2008, 15:11
