  1. Hi everyone I am new in here
    i want to ask to all of you. I just bought macintosh ** only a week**and since I am also not that familiar with macintosh. I have problems with trying to capture every frame from movies.
    the only way tht i capture every frame of some movies by my self is with click Command + Shift + 3
    so do you guys know the better way or recommend me with some software so i can automatically capture every frame fom some movies..
    thanks
    note: i am really dumb
  2. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Well, it depends on what you want to do with the captured video. I doubt you actually want to get a screenshot of every frame in the movie. If this is a DVD, and you want to copy it, there is software for that. You need to expand on what you're trying to do, what you're capturing, and what you plan to do with the captured material.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
  3. The simplest way is to pause (via the DVD Player) the video on the drame you want, click in the image and drag it to the desktop. You will then have a PICT clipping of the frame which you can play with.
    william
  4. no this is not dvd
    its just like let say i have short quick time file and i want to capture it every frame from that file and also i am want to make it became animated gif file
    is there anything to make my life more easier rather than using click Command + Shift + 3
    thanks
