Does the INTEL Desktop Board D875PBZ support Ultra ATA/133 hard drives? ..i'm using 80GB ultra ATA 100 2mb but i am thinking to add a new hard drive.....160GB Ultra ATA 133 8mb.the thing is i dont want to spend alot of money on ATA 133 if my computer doesn't support 133.
another question is ....if i use 2 hard drives 100 and 133 at the same time...it's gonna run at 100 or 133?
i think i have to add a card to run at 133
thank you
As near as I can find, it doesn't offer ATA133 support. If you have this board already, I wouldn't be afraid to use a ATA133 drive. Most of the time I doubt if you would notice a difference in speed between 133 and 100. Be sure to use a 80 conductor cable (probably included with the drive). Seems strange to me that this board doesn't offer ATA133 support. You can use a seperate controller for ATA133, but it may not be any faster. As far as mixing ATA133 and ATA100 drives and what speed they would run, it depends more on the board than the drives. Most drives will never operate at their listed speed. The ATA133 is probably a good choice.
yes ....this is weird ...my motherboard is pretty new and it doesn't support 133. anyways ...since my motherboard doesn't support 133 ...can i still use that 133 drivel?or i can't use that 133 drive at all in my system?
Yes you can use it just won't go at 133 only 100 but you'd never notice the difference anyways
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 15:58
