  1. Hi.
    I recorded 15 dvd-r, half using Nero and half record max.
    Here´s the problem, it works perfectly im my dvd-rom driver in my pc. but it doesn´t work in any of my dvd players
    Sony and Pioneer compatible dvd-r player and in my Ps2.
    It doesn´t work in any of this players
    Any ideas of what should I try to do???
    Thank u
  2. What brand of media do you have?
    What brand of writer do you have?
    Hunting, sure i'll go hunting. When is cow season?
  3. Nero has done that to me as well. I just don't trust Nero for burning DVD's anymore. I create an image first of the completed folders and burn them with DVD Decryptor. The DVD's now play perfectly.
  4. media is from a factory BICTEL
    and recorder is PIONEER
  5. If you have a SONY standalone dvd player that is your problem. I have a sony dvd player (DVP-NC600) and any DVD-R I made that has an altered "ifo", it will NOT play. I will get the error message "C:13".
    This is a disk calibration problem and there is no remedy to fix it.
    Most DVD'R's will play that don't have an altered "ifo". These are straight-backups or only the movie backups. By altered "ifo", I mean a method that produces a DVD'r containing only the Movie and the Menu.
    Like you, my laptop's DVD drive will play the disks as well as a Mitsubishi standalone DVD player I have, but not my Sony standalone dvd player.
  6. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    I've had a Sony and it did play DVD's with modified IFO's as I always butcher DVD's and they played back fine as long as I did the job properly
    the couple of issues were my own doing with silly mistakes , but a quick mod & reburn sorted that
