Ok here goes, i'll explain this the best i can.
I captured some cartoons (Bob and Margaret they are called), i captured them with xvid max CBR 640x480. I then i used vdub to cut out the adverts and end credits making each show 20 minutes long give or take a few seconds, then i compressed them with xvid through vdub again with xvid 1 pass quantizer on a setting of 5 (or so i thought) turning each show out at 100 megs or thereabouts, i captured and compressed the first 6 shows in that way, now when i try the same thing i have to use a quality setting of 9 or 10 on the quantizer to get the same filesize, or maybe i am just going a bit crazy and imagined i compressed the first 6 at quality setting 5, i dunno.
Any ideas what may have happened if anything at all happened, or am i imagining this?
I have set the defaults on xvid and started rom scratch, also reinstalled my o/s,.
Cheers.
Results 1 to 1 of 1
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
Xvid Setting: 1pass Quantizer vs Bitrate Mode, vs 2pass => Quality
By carlaron in forum Video ConversionReplies: 12Last Post: 4th Oct 2010, 08:12 -
XVid Target quantizer / Bitrate Analogy
By drgt in forum Video ConversionReplies: 3Last Post: 19th Sep 2010, 12:33 -
Xvid Quantizer Codecs
By theninger in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 11:54 -
XViD 2nd pass problems
By shorto in forum Video ConversionReplies: 2Last Post: 22nd Dec 2007, 18:31
