  1. Member djmattyb's Avatar
    Dec 2001
    Seattle
    When using DVD Shrink, if I have removed enough when re-authoring a DVD and the compression says '100%', will selecting 'deep analysis' make any difference in the quality, or does the 'deep analysis' only effect the output when you have to apply compression ie transcode? If my question doesn't make sense, please let me know!
    Thanks!
    dj matty b
  2. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    If 100% no need to use it
  3. To make sure that the video stream will be left untouched when the ratio is 100%, choose "No Compression" instead.
    P.S: as Sifaga said, Deep Analysis is only useful when compression is required (most users do not use it until the "Ratio" gets below 10% or thereabout)
    ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
