Hi, I am having a problem syncing my audio. I'm using a wintv pvcr 350 to capture mpeg 1/2, when capturing with that the mpeg files audio seems to be a hair off, but then when I try to author a dvd with tmpge dvd author the files audio is way off. Is there some setting in one of the programs i'm missing? The program i'm using to capture the initial mpeg 1/2 file is wintv2000 that came with the capture card. PLEASE HELP!!!!
Try loading the video into Virtual Dun mod and check for bad frames.
Hello.
Audio Sync Problems
By nephesh in forum Video Streaming DownloadingReplies: 0Last Post: 12th May 2011, 09:10 -
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 10:49 -
Audio Sync Problems
By Blue_3 in forum AudioReplies: 5Last Post: 10th Apr 2008, 19:17 -
Audio sync problems
By sticklebrick in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2007, 15:14 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 07:22
