i ordered this dvd from spain and it's under region 2 so naturally my dvd player wont play it (samsung 709) and i've tried that region free code using the remote control and i get nothing, so what is my best bet? should i rip it into the computer (my cousins computer) and burn them into a dvd or should i just copy the dvd, i'm afraid that copying the dvd would result in the burned copy still having that region 2 setting. Any suggestions
Rip and burn. DVD Shrink can let yo select certain regions, or no regions.
Hello. -
thanks for the info but will it allow you to burn vcd's, and also when you rip the dvd using this software the files it creates can you use them to burn a vcd using a different program
Sure, open the VOBs in Virtual Dub mod. Frameserve them TMPGEnc and encode them to MPEG VCD format. Then use a program like Video Studio, or VCD Easy to burn to VCD.
Hello. -
for some reason whe i ripped the dvd it split into 3 files and the first one was at least a GB and i couldn't burn it being to big, is their any form of ompression i should use? is there a way to hack a samsung 709 dvd player i've tried those hacks posted on this but they don't work as soon as i tried to put in the code i get the universal no sign
DVD Region problem
By elty in forum Newbie / General discussionsReplies: 3Last Post: 12th May 2011, 09:39 -
Blu-Ray Region Problem?
By Wee_Willie in forum Authoring (Blu-ray)Replies: 13Last Post: 18th Jul 2010, 10:50 -
region 2 dvd problem
By aprilluis in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Mar 2010, 18:47 -
Problem with Region settings
By paulgold in forum DVD RippingReplies: 11Last Post: 18th Apr 2008, 21:47 -
Region problem with Pioneer
By bltprf in forum DVD & Blu-ray WritersReplies: 10Last Post: 28th Jan 2008, 04:36
